Hey everyone- I've got 700 miles on my 2004 Ranger XLT 4x2 Supercab manual transmission with the 3.0 V6 and I'm already wishing I had the 4.0. The engine doesn't feel 'smooth' at all- definitely not like a brand new car should feel like. Does it get better after the break-in? Also, I've heard that I should get the oil changed a few times during the first 1500 miles or so is this true?
Deffinatly change the break-in oil.The best way to set the DRIVE CYCLES in the PCM is to use the STEADY FOOT method.excellorate steadly and dont floor it,while driving,hold it at a constant speed,dont speep up and slow down alot.It takes like 40 cycles to set it to your driving paterns,(start,drive,let cool )Also try excellorating from 20 to 50 at 3/4 throttle then coasting down to 20 and do this 3 times in a ROW.There are about 10 other things like this to do but I cant find the post for them.It will eventually learn on its own it will just take some time.
I've got a new XLT 2.3L / auto and I've had the same impression. I'm up to about 180 mi and there has already been some improvment in both smoothness and pep. As for the first oil change, there is a lot of debate on what's best. For everything and MORE you ever care to know about oil, go to bobistheoilguy.com. It's really a cool site even if you just lurk.
My first rule of thumb is - Take it back if it is still under warranty. Make them check it out. It could be something simple, just make them do the work.
Rainan, I bought a new 2002 Ranger with the 3.0 and automatic. The idle was rough, but the roughness either went away or was not noticeable at road speed. I took it back to the dealer who told me "they all run like that". I didn't believe them, but had contacts at Ford dyno lab. They checked it out and gave me an answer: Ford eliminated the EGR valve on this engine by changing the cam profile. The result was a rougher idle, but no EGR valve. I guess I believe them. If a different cam grind can eliminate the EGR valve, I guess it could be considered an improvement. Knowing this makes me feel better about the rough idle. However, I think the roughness is permanent and annoying. At least it is not a symptom of something going bad. (Mine is still idling rough after 3 years and 22,000 miles.
