1966 - 1977 Early Broncos
power steering swap!
Old May 24, 2004 | 05:02 PM
oldgabe01's Avatar
oldgabe01
Question power steering swap!
Has anyone else heard that a exterra power steering box is a bolt in replacement for early bronco's. I read this just the other day and thought id put the question out there. It would be nice if it is true
Old May 24, 2004 | 09:09 PM
69_bronco's Avatar
69_bronco
Don't know about the exterra, but I used a '86 toyota 4x4 steering box on my '69 and it workred great. There are a few things you have to do to make it fit, but two of the mounting holes line up with the ones on the manual box.
The Early Bronco Registry has a bulletin on their web site that tells you what you need to make the swap. I spent about $300 on the parts.
Hope this helps....
Old May 25, 2004 | 11:11 AM
csangster's Avatar
csangster
Exterra box
It is NOT a 'bolt in replacement'....but I have heard of people putting one in.
The things I recall that you will have to deal with are modifcation of the pitman arm to accept the drag link....
I'm not sure what you are looking at, but a swap that is popular among the early bronco people is putting the Ford F150 4x2 internals into a Ford 4x4 box.
You can pull both boxes from a yard for around $35 ea and do the swap that is detailed on www.bcbroncos.com.
Ford F150 box you are looking for will come out of the Mid 70's 4x2 F100-F150, the 4x4 box can be pulled from a 78-79 bronco or other 4x4 Ford pick-ups of that timeframe.....
Check out the above website for more details. I personally did not do this swap, I just grabbed a setup off of a 76 and it was plug and play.
Hope this helps,
Chris
Old Jun 11, 2004 | 02:30 PM
hdbugs's Avatar
hdbugs
Power Steering box
I have done all three, and presently using a Toyota box on my 69' Like the previous poster just one hole to drill. Hoses can be a challenge.
Roger C
Feb 16, 2017 09:57 AM
sonny1965
WTB - Parts & other
Nov 28, 2016 03:13 PM
6t6merc
19
Feb 15, 2002 01:01 PM
twr
Jun 20, 2001 05:52 AM
jowilker
Feb 15, 2000 08:41 PM
