Best Van/Engine/Auto-Trans combo???
What would you consider the best combination of van/engine/auto-transmission for the following purposes:
1. towing a trailer from 2000lbs to 4500lbs (my estimate of a minimum utility trailer with storage stuff, including wood, to a maximum of an older 16’ travel trailer… I might be off on the max weight)
2. best gas mileage (optimum is 18mpg, acceptable is around 15mpg, min is 12mpg)
3. best overall performance (I can work on it myself, but don’t want to if don’t have to)
4. looking at older models in the less than $5K range – and body is not nearly as important as engine, but looking for long-body models
... looking for your opinions on year (obviously older model) and engine size and trans type ... which combo is your favorite and why? If it varies tremendously based on my towing (purchase not made yet for trailer), then can you give me your top two choices (for min and max tow weight)?
Thanks,
Next best would be a V10. Milage is worse but good power and towing ability. Wait just thought of something, the van V10 has less power than the truck version. Alot less, never driven one though so don't know how noticable it is.
As to the medium level gas engine 5.7 vs. 5.9 vs. 5.4, the dodge seems to be happier, with a load, but the 5.4 is not far behind. the 5.7 is just plain weak compared to the other 2.
