Dead Navigator
Old May 23, 2004 | 11:42 PM
Sire_Taz's Avatar
Sire_Taz
Dead Navigator
I have replaced the battery and the alternator and still if it sits for more than a few days, it will not start without being jumped....Pls help
Old May 24, 2004 | 12:35 AM
pounder90's Avatar
pounder90
Make sure that the system is charging first. Measure that the voltage across the battery is around atleast 14 volts with the truck running and all accesories off. If it is, check for a current draw. There is a better explanation of this test (and diagram) on the electrical forum, but here is the jist:
1. Turn the truck off
2. Turn off all accessories
3. Disconnect the negative lead from the battery. Connect your voltmeter or test light in line with the battery terminal and the (-) lead. If you read more than several millivolts or your test light lights up, you have a current draw.
4. Pull and replace one fuse at a time until the meter reads 0 or the light goes out.
5. Troubleshoot that circuit.
Good luck.
Old May 24, 2004 | 11:12 PM
Sire_Taz's Avatar
Sire_Taz
will try that thanks
Old Aug 10, 2004 | 10:05 PM
StormyKnight's Avatar
StormyKnight
Battery Draw
I've got a '98 Exped. and have the same symptoms. Local mechanic told me about connecting multimeter and pulling fuses to find the electrical draw. I've been through every fuse I can find (believe me, there's a lot) and even started pulling connectors apart. No dice. nothing stopped the draw. (btw. I did go through the obvious things like interior lights left on, sun visor mirror light, etc., I even pulled the CD case . It also has a new alt. and Bat.) I cannot find the draw anywhere. the draw is about .3 amps. my mechanic friend told me there should be a draw of about .003 amps, but it's not enough to bother anything. If anyone has any ideas, please let me know. Thank you!!
Old Aug 11, 2004 | 07:21 AM
mapman's Avatar
mapman
One of my friends has a 97 expy, if she lets it sit 3 or4 days it would kill the battery. Hers was a short in the drivers side door interior light button.
Old Aug 12, 2004 | 08:27 AM
StormyKnight
I will look into that. My latest efforts include isolating the alternator, and lubricating all the door and hatch latches. I did find something very strange. When I isolated the alternator, I also unhooked the other end of the alternator wiring, that is, I unhook it from the solenoid, removed the alternator field minifuse and unhooked the connector that plugs in behind the megafuse block. When all of this was unhooked, the draw stopped!! As far as I could see, these wires were not hooked to anything. Now, if I touched the main hot wire(the big red one) to anything, including the radiator hose or even myself, there was a draw, the draw being higher/lower depending on the conductivity of the material it was touching. HOW CAN THIS BE???? The only place these wires are connected to anything is at the alternator megafuse which itself is isolated from any ground. I'm really stumped on this one.
