Delayed gauges
Old May 23, 2004 | 11:38 PM
stksux's Avatar
stksux
Delayed gauges
Hi, the prob I have is when I start up. Its every time. I've checked the conns and fuses, but still it persists. Any ideas out there. Thanks
Old May 24, 2004 | 12:23 AM
pounder90's Avatar
pounder90
It sounds like its time to replace your battery. I had the same thing happen several months ago. I posted on here and PaulC confirmed right away that it was the battery. It was the fix, thanks again PaulC. My gauges actually did a sweeping motion before settling on the correct readings. I have also seen posts of gauges pegging themselves also (again battery). Good luck.
Old May 24, 2004 | 06:11 AM
18fan's Avatar
18fan
The battery was weak on my 99 and caused the guages to do the same thing. They hesitate for a second then jump to normal. Have the battery checked.
Old May 24, 2004 | 05:21 PM
2000Expy's Avatar
2000Expy
Question delayed oil pressure gauge
Hi,
I've had this problem with only the one gauge. I wonder if the oil pressure sending you unit is beginning to fail. Any ideas?
Old May 24, 2004 | 06:05 PM
asinatra's Avatar
asinatra
You can't just immediatly start your engine and have oil pressure...
Old May 24, 2004 | 06:13 PM
triton_2002's Avatar
triton_2002
I agree with bad battery, my truck did that a couple of times before the battery finally died.
Old May 24, 2004 | 08:30 PM
tsdrallyer's Avatar
tsdrallyer
If only on one gauge, check the sensor for that unit before suspecting the gauge itself.
