Some questions....
Old Sep 16, 2001 | 08:23 AM
OutlawT76's Avatar
OutlawT76
Some questions....
After reading many of the posted messages....
What is the "soup bowl"? I assume it to be something in the intake tract.
Who makes an exhaust system for a 94 F-350 7.3 I.D.I Turbo? I'm looking to replace from the turbo all the way to the tail pipe.
Thanx.
Old Sep 16, 2001 | 10:24 AM
powerstroker250's Avatar
powerstroker250
Some questions....
I don't know what the soup bowl is but you can check out www.bankspower.com for you exhaust.
Les
Old Sep 17, 2001 | 05:18 AM
argve's Avatar
argve
Some questions....
The "Soup Bowl" is on the inside of the air cleaner assembly on the Early Diesels. When you would open up the air cleaner cover on mine you could not get the lid off because it had a bowl installed that extended down in the center of the housing. So the only way to check the filter was to pull the entire assembly.
This "Soup Bowl" resticts the air flow, and also keeps the noise down. I cut mine out and the throttle response improved, this was even after adding the K&N air filter.
I am not sure about your factory turbo, I believe that it uses a different air induction system. My air cleaner assembly looks like a normal air cleaner housing from back in the 70's. Uses the ole round filter, that drops in with wing nut on top of the cover.
1991 F350 CC Dually 7.3l, E40D, Soup bowl removed, K&N
Old Sep 17, 2001 | 08:38 PM
OutlawT76's Avatar
OutlawT76
Some questions....
Thanx...I was thinking the "soup bowl" was something inside the air filter housing.
Also, I've been looking into Banks for exhaust systems and will be giving them a call to get some more info.
What's a good spot to hook up a boost gauge line?
Old Sep 19, 2001 | 10:42 AM
powerstroker250
Some questions....
