Diesel Mileage
Old Aug 6, 2001 | 12:35 PM
BigGreenFord's Avatar
BigGreenFord
Diesel Mileage
Hi,
Am considering getting a new full size pickup and was wondering if it is worth considering the diesel powerplant for better mileage?
The thought being that in a heavy full size the Ford diesel should get better mileage then the gas motors.
It's hard to compare since they don't post mileage numbers for diesel trucks.
Thanks,
Phil
Old Aug 6, 2001 | 09:22 PM
SctS's Avatar
SctS
Diesel Mileage
The MPG question always seems to bring a wide range of responses. I've seen everything from 13 City to 23 mixed.
Personally I'm driving a 2001 SC 4x4 6 spd and average 18.5 to 19 with mixed city and highway driving. While I don't take it too easy on my rig, I usually don't take off too hard.
When on the open highway pushing speeds of 80, I've noticed a drop down to 17.5/18.
I went through the gas/diesel debate two months ago, ended up with the diesel and have been glad I did every day since.
Hope this helps.
Old Aug 6, 2001 | 11:24 PM
argve's Avatar
argve
Diesel Mileage
A diesel will get better MPG every time, the draw backs is they are not quick on take off, and they cost more on the purchase price. But after about 70,000 miles you will ahead. This is considering everything even oil changes.
Just remember run the additive in both the cooling system and fuel system. FW-16 is the coolant additive from Ford. Standadyne makes a pretty good fuel additive. There are many different brands of coolant additive and fuel additives on the market. I recommend using both, mainly the coolant additive. Diesels suffer from cavatation and you can kill a block in as little as 60,000 miles. I know, I purchased mine used at this mileage with cracks in both #2 and #6 cyl.
1991 F350 CC Dually 7.3l, E40D, Soup bowl removed, K&N
Old Aug 6, 2001 | 11:27 PM
argve's Avatar
argve
Diesel Mileage
almost forgot to mention that I am getting 15-17 MPG. I have a 4.10 rear gear.
Old Aug 27, 2001 | 01:29 PM
hodgekuter's Avatar
hodgekuter
Diesel Mileage
I just bought a 2001 f 250 auto,e/w3.73 gears,psd and I love it. And it gets great fuel mileage, ave. 18.5 unloaded, 12 towing 8000 lb 5th wheel.
Old Sep 23, 2001 | 05:17 PM
redneckdieselmechanic's Avatar
Diesel Mileage
Diesel engines always seem to get better gas milage due to much higher compression than a gas engine. They make better torque, about the same horsepower a gas engine makes and diesel fuel is usually cheaper than gas, but not much nowadays. A diesel engine should last about twice as long as a gas engine if maintained (everything seems to last longer when properly maintained).
Old Sep 23, 2001 | 08:02 PM
fordiesel69's Avatar
fordiesel69
Diesel Mileage
bikemad
Aug 4, 2011 12:53 PM
Barty88
General Diesel Discussion
20
Feb 19, 2011 08:11 PM
apeman426
Mar 14, 2008 04:03 PM
jeffrey rasmussen
Oct 9, 2007 06:36 PM
lkh
Car/truck Buying Advice
Mar 5, 2005 10:39 PM
