glow plugs
Old Sep 24, 2001 | 12:55 PM
dumontkid's Avatar
dumontkid
glow plugs
just want to know how to check the glow plugs on the powerstroke. i assume you can pull the electrical connector apart at the valvecover and use a multimeter. if i remember right there are three contacts at each lead, which one is which?
bryan
Old Sep 28, 2001 | 04:14 AM
The Diesel Dude's Avatar
The Diesel Dude
glow plugs
If you have the engine with one connecter on each head cover gasket, the 4 outboard pins, that is the first 2 and the last 2 are the glow plug terminals. If you have 2 plugins on each head cover gasket, the 2 outermost terminals on each plugin are the glow plug terminals. Just unplug the harness and check the appropriate terminals to ground with a multimeter or a dead light.
Old Sep 28, 2001 | 03:56 PM
logan_85's Avatar
logan_85
glow plugs
