new member needs help
Old May 23, 2004 | 11:07 AM
piddlar's Avatar
piddlar
anyone have 1965 f100 240 engine capacities and tune up specs?
Old May 23, 2004 | 11:39 AM
camperspecial65's Avatar
camperspecial65
Tune up specs are as follows... Idle: 500-525, both M/T and A/T(in drive)
comression specs should be around 150-200
Timing: 6 degrees BTDC, 8 degrees w/auto. trans
oil pressure 35-60hot at 200 RPM
Plug gap .032-.036
dwell 35-38 degrees @ idle/ .024-.026
If you need more info, give a shout. this is all per 65 shop manual
cs65
Old May 23, 2004 | 11:48 AM
camperspecial65
Capacities....
Oil 5 qts w/new filter(book says 4 1/2)
Cooling system 19 qts(add 1 for heater)
Fuel 18 gal.cap.Rear end...4 1/2 pints
Trans cap(cruise-O-Matic...10 qts approx, C-4: 10 qts 7.5 0z. approx....dont understand the approx with an oz spec given...Mercron fluid only.
Old May 24, 2004 | 09:01 AM
piddlar's Avatar
piddlar
thanks a heap camperspecial65
Last edited by piddlar; May 24, 2004 at 09:03 AM. Reason: forgot name of person I am thanking
