General Automotive Discussion
lost key
Old May 23, 2004 | 09:56 AM
jfranc1's Avatar
jfranc1
lost key
I lost the key to an 83 F-250. How do I change the tumblers?
John F.
Old May 23, 2004 | 10:08 AM
Dealford's Avatar
Dealford
Welcome to FTE.
Is the door key the same as the ignition?
If so, remove the door lock and take it to a locksmith and have a key made. It's not that expensive.
Just a thought.
Old May 23, 2004 | 10:48 AM
jfranc1's Avatar
jfranc1
Thanks, but keys are different. Thanks for the tip!
Old May 24, 2004 | 12:05 AM
chaseface84's Avatar
chaseface84
i know when my friend lost his key to his isuzu trooper they call the dealer with the VIN and they gave him some numbers, they then took those numbers to a locksmith who cut a new key for 50 bucks his trooper was a 93 though. I dont know if they did that back in 1983. In my experience you usally have to have the key to put in a new lock cylinder.
Old May 24, 2004 | 12:08 AM
clarko's Avatar
clarko
Have a locksmith break the tumbler to the on position then pull the steering wheel and insert a pin into a tiny notch that will let you pull the tumbler out, then get a new one and put it in.
