CMP Question
Old May 23, 2004 | 08:35 AM
bbeck45's Avatar
bbeck45
CMP Question
Ok if the cmp is going out will it cause the problem intermittently, The truck will run fine and every once in a while lose all power, and after about 30 sec with me pumping the pedal will"come back to life" and run fine. I am going to try the filter it looks pretty nasty, but just in case I could use some feedback. Thanks 95 PSD F350 4x4
Old May 23, 2004 | 10:07 AM
bbeck45's Avatar
bbeck45
just a note I just picked up a CAMP sensor from international, for the older serial numbers the part number has changed, it's 1821720C99, I'll let y'all know how it turns out
Old May 23, 2004 | 10:10 AM
wlihntr's Avatar
wlihntr
yep, that is what mine did when it went out. it will just die and in a little while fire right back up
Old May 23, 2004 | 11:12 AM
bbeck45's Avatar
bbeck45
Well it was a combination between that and low oil...at least it's running now, thanks ...
Old May 23, 2004 | 12:36 PM
Lagerhead's Avatar
Lagerhead
Bbeck dose the motor ideal but will gain RPM. if so it is the pedal you may be able to cleanthe TPS mine did as I described 500 miles from home cleaned if some elcitronic parts cleaner and has work great since
