Sponsored by: Real Truck
weak horns
Old May 22, 2004 | 02:11 PM
veritas137's Avatar
veritas137
weak horns
So one thing that annoyed me about my truck was the weak horns. Dual horns, but located in the fender made them pretty quiet, my mom's Camry was louder.
I still had my Hella triple's laying around so I installed them this morning... much better. Now when I hit the horns the truck screams "GET THE HELL OUT OF THE WAY!"
Old May 22, 2004 | 04:55 PM
n578md's Avatar
n578md
That's the very first thing I did, the day after I drove my truck home. I installed a single air horn from an old F700. I had to buy a large direct drive air compressor and a 30 amp relay. I fed the compressor directly from the battery via a 30 amp fuse and the relay and I used the power feed off the wimpy factory horn as the signal wire to the relay that way the steering wheel horn pad sounds the horn, no extra buttons. Everything mounted with quick connect spade terminals so it can be taken off easily. (I've had this thing on 4 trucks already.)
