Wisconsin Chapter Join Chapter Leader:
Muddin'
Old May 22, 2004 | 05:07 AM
mick460's Avatar
mick460
Muddin'
I know with all this rain there are trucks out there just covered in mud. So where are you getting dirty?
Old May 23, 2004 | 11:38 AM
mpcrewcab's Avatar
mpcrewcab
no playing here--trying to bail water out. Although the fields are looking like fun and the creek than runs through the field is over its banks. Anyone playing??
Old May 25, 2004 | 09:58 AM
BlackedOut 86's Avatar
BlackedOut 86
Gotta have a truck that runs to go out and play
I wanna get my truck fixed very soon before all this dries up so I can go out w/ it...Prolly make a quick trip to Machickanee w/ it since that is the closest place to me that I know of. But I don't know what's wrong w/ the Bronco, or how much it's gonna cost to fix. Only thing I do know is it needs a tranny, but that is minor rite now, cuz I still got 1st and 2nd gear and that's all I need
Old May 28, 2004 | 03:52 AM
Boss50's Avatar
Boss50
I'd like to go on The Pipeline but my truck's only 2wd. I'm limited to old, slippery hay fields. I might hit the pipeline when the bronco gets fixed, and then have to fix it again.
Old Jun 2, 2004 | 01:44 PM
KJKozak2's Avatar
KJKozak2
Where were you guys Memorial day and the weekend brfore?
I went up to Athelstane to McCaslin Mountain Campground Memorial Day weekend and the pipeline the weekend brfore.
The campground is only an hour north of green bay and the pipeline is 3/4 miles from there.
Mem Day was a total BLAST! HERE are some pix I took.
Kevin K.
Old Jun 2, 2004 | 08:43 PM
Ford79's Avatar
Ford79
Hopefully your weekend went better than our's did. Started out Saturday installing a locker in the front of my buddy's truck, got it back together just in time to make our scheduled trail time at Trollhaugen (Dresser) and promptly broke a front axle u-joint (I knew they should have been replaced) and also twisted off the axle shaft only 1/2 hour into our trail ride. Went back home and tore the front end completely apart again(had to remove the carier to get the broken axle piece out) for the second time in less than 6 hours. We didn't get the truck back together until the next morning after taking more parts off my rolling chassis in the shed. Had more problems with the brakes (air in lines, leaking lines, etc) and after the brakes were fixed, the shift linkage broke inside the steering column(again, I had a spare lying around). After it was all said and done, we missed the trails by 1 hour, they close them at 3pm.
Old Jun 3, 2004 | 09:07 AM
KJKozak2's Avatar
KJKozak2
Man, does that suck!
Yeah, ours actually went pretty well. Like the last few years, the first hour on the trail my cousin busted some stuff. Fell into a rut coming down the hill and hit a rock with the front left. Sheared the centering pin off the leaf springs and shoved the axle back, which stuffed the front wheel up into the body. Then broke a u-joints on the other side. Luckily, it wasn't that bad and we had it fixed first thing Sat. morning.
I actually went all weekend without getting stuck or breaking anything major. I bent the tie rod and popped the stabilizer bracket off the frame, but that's it.
Once I resolve some clearence issues, I'll be ready again.
Kevin K.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
