Creeking and cracking
Old May 21, 2004 | 03:55 PM
302truck's Avatar
302truck
I have a 1993 F150 that creeks and cracks when you go over curbs. I changed the radius arm bushings, no help. I have axle bushings ready to install. ANY help is appricated.
Old May 21, 2004 | 04:28 PM
fai4g63's Avatar
fai4g63
I have a 86 F150 and my truck makes popping noises every time I make a turn. I heard there is a TSB on this. If I recall, the problem has been solved by replacing loose frame mounting rivets. Also by installing a insulator on the trans crossmember where it bolts to the frame.
Good Luck
