Major AC problem
Old May 21, 2004 | 09:23 AM
Gil Chesterton's Avatar
Gil Chesterton
Major AC problem
Hello folks,
I own a 1991 Explorer XLT (200,000 miles).
Recently my AC clutch-pulley ground itself to dust. It seemed the clutch plate and compressor were in decent shape just the bearing in the pulley had worn.
Normally I would have changed out the whole unit but I assume I have an R12 system and therefore would have to convert to R134 therefore the whole job would be rather costly. This is the last summer I will run this truck so I opted to replace the pulley only ($100.00 from Ford).
I replaced the pulley two days ago and I don't think the compressor is cycling properly. I get cool air but not cold and yesterday the pulley-clutch unit heated up so much it began to smoke. Not good.
Any idea what may be happening here? I don't even know where to start. It could be mechanical (compressor shaft warped causing wear?) or maybe AC related (cycling on and off too often due to low freon?).
My knowledge of AC systems is limited.
Thanks,
Gil
Old May 21, 2004 | 02:46 PM
bcjim's Avatar
bcjim
Try and find a used compressor in a junkyard would be my advice, otherwise, 13 years and 200K, thats a pretty good run.
Old May 21, 2004 | 10:59 PM
azerndt's Avatar
azerndt
you're right about the R12 by the way. i don't know if you have to convert the entire thing to R134a - i would also look and see if you can find the part you need aftermarket or a junkyard
Old May 23, 2004 | 06:27 AM
marragtop's Avatar
marragtop
When you put the pulley on, did you put any shims in it? If you have to pull the compressor and recharge the system, I would convert to 134. It's easy to do.
Mike
Old May 24, 2004 | 02:34 PM
Gil Chesterton
Hello,
I think I will get the replacement from a wrecker. If I can get the system discharged at an approved shop I will change it over myself (mechanical installation of the replacement compressor) and then get the shop to convert and recharge R134.
Can I do anything myself on discharge R12 or R134 conversion? All the information I have is that this part of the job is best left to the pros (EPA restrictions etc).
Thanks for your help.
P.S. Marragtop - shims? Only a retaining clip. Did I miss something?
Old May 31, 2004 | 10:40 AM
Gil Chesterton
Hello again,
I have had the system discharged and purchased a used compressor. I will have the vehicle converted to R134a at a local shop after I install the unit (it has also been suggested to me to have the shop replace the accumulator).
Is there anything I need to know about installing the compressor? How much oil needs to be added? Which type? Any other pitfalls? Mechanic's secrets?
Any help would be appreciated otherwise I'll pay the extra $100.00 and have it installed at the shop.
Thanks,
Gil
Old May 31, 2004 | 07:15 PM
srercrcr's Avatar
srercrcr
This will blow your mind....the new refrigerant is going UP in price and the old R12 is coming DOWN in price.
X-70STANG-F150
1997 - 2003 F150
Nov 26, 2014 06:37 AM
Togglebolt
Feb 18, 2013 06:21 PM
Pete in Maine
Dec 20, 2012 04:24 PM
Big Skier
Jun 3, 2012 12:39 AM
75_92_95
Jul 15, 2011 06:10 PM
