Computer Chips & Tuners
Start Running Premium Now?
Old May 20, 2004 | 11:55 PM
dzeltman's Avatar
dzeltman
I just got notice my DiabloSport chip is in the mail. I did half a tank fill up on premium (91, highest I can get in CA) so should I do a full fill up on 91 and wait to put in the chip?
Also, can anyone recommend a good octane booster? I saw some articles online about adding tuolene (sp?) to get some some good octane boost.
Any ideas would be great.
Old May 21, 2004 | 11:13 AM
ssn randy's Avatar
ssn randy
run it until the light comes on then filler er up with 91 and have fun!
Old May 21, 2004 | 03:47 PM
AG4.0's Avatar
AG4.0
If you've got half and half now, I'd run it doww to at least 1/2 to 1/4 tank to put it in to be fine. But you will have the best results if you run it all out.
Old May 21, 2004 | 08:29 PM
dzeltman's Avatar
dzeltman
Actually, I was on vapors, then filled half a tank with premium. So it's pretty much all premium now.
What about an octane boost? Any ideas?
Old May 22, 2004 | 07:28 PM
boxcar1974's Avatar
boxcar1974
octane booster just dont work. I am sure the webmaster will chime in about that. The most you can expect is .2 octane.......yes that is POINT 2 octane.
Old May 23, 2004 | 11:18 PM
FTE Ken's Avatar
FTE Ken
100% premium, no octane booster.
Old May 24, 2004 | 08:55 AM
dzeltman's Avatar
dzeltman
91 is the highest I can get here in CA, is that going to be OK?
Old May 24, 2004 | 11:24 AM
ssn randy's Avatar
ssn randy
yes, no less than 91 on performance or performance tow modes. engine ping could result causing some damage to your engine.
Old May 24, 2004 | 02:26 PM
dzeltman's Avatar
dzeltman
SCHWEET
I get my chip tomorrow and now I know what I am doing after work tomorrow...
heh heh....
Old May 25, 2004 | 12:54 PM
ssn randy's Avatar
ssn randy
tell us how it goes.
Old May 25, 2004 | 10:02 PM
dzeltman's Avatar
dzeltman
So I got it in.
I followed the instructions till I pulled the ECU. I don't know if you know this (moderator) but the 02 Ranger's ECU is encased in an alluminum case. I had to take some snips to get at the rear contacts. Once done, I put on the chip. I put the tape on the back and put everything back together and did a hail mary even though I'm not Catholic.
Well, it started.
Quick question though. How long does it take for the chip to re-do the ECU code? Do I need to drive it longer than around the block? Any feedback would be great. Thanks for interest in my thread.
BTW, this is my first mod on this truck.
Old May 26, 2004 | 09:24 AM
ssn randy's Avatar
ssn randy
chip takes effect immediately overiding the factory parameters, however the pcm also is learning as it goes and makes fine adjustments to the a/f tables and timing as you drive. it learns YOUR driving habits and adjusts accordingly-meaning drive it like you stole it. heavy foot means more timing and a/f ratio. its an adaptive strategy so drive it about 500 miles and you should see the improvements at full strength.
what a great mod to start with, good luck.
Old Jun 3, 2004 | 01:13 AM
dzeltman's Avatar
dzeltman
Nice...
The butt-dyno says this is working very nicely. I have noticed a bigger pick up off the line and nicer shifting. It really wants to go.
My next mod id a Gibson cat-back...should sound nice.
Old Jun 3, 2004 | 08:57 AM
ssn randy's Avatar
ssn randy
do a search on magnaflow mufflers, straight thru, more power and a good sound without drowning you out in the cab. my opinion, do the search and read for yourself.
good luck, glad your liken the truck!
Randy
