3 speed tranny problems.
Old May 20, 2004 | 11:37 PM
handx2's Avatar
handx2
i have a problem with my 3 speed grinding.it happens anytime i shift into second.especially when downshifting.it also grinds when shifting into first after the truck has been idling in neutral.can i rebuild this tranny myself?how do i check the fluid level,it is forty years old and probably needs changing.what kind of fluid does it take?what kind of auto trans are available for 292?where could i find one?
Old May 21, 2004 | 08:34 PM
JSMConstruction's Avatar
JSMConstruction
Question
Well it sound's like a decent tran's and it seem's it may have 2nd gear going out on it or the Cltuch is getting weak.....
I'd hate to say it But could it be the driver don't know how to drive a 60's manual transmission???.....
Old May 21, 2004 | 09:11 PM
handx2's Avatar
handx2
well,i guess it could be the driver,but i`ve been driving it for several months now without any problems
Old May 21, 2004 | 09:33 PM
dusty64f100's Avatar
dusty64f100
mine grinds into second & sometimes wont even go. I got someone to watch the clutch and it slides sideways before turning. it's barely clutching even when it's all the way to the floor. i haven't had time to look at it but could I put a spacer on the end so it wont slide or is there some reason why it's doing this?
Old May 22, 2004 | 12:02 AM
JSMConstruction
Talking
No i wasn't trying to cut you down i've had people ask then i found out they have only driven this a few times and it's there frist truck..............
Old May 22, 2004 | 12:03 AM
JSMConstruction
Lightbulb
yea just have to remind your self this truck is 40+ year's old and maybe touchy at time's.............
Old May 22, 2004 | 07:38 AM
banjopicker66's Avatar
banjopicker66
If your clutch compnents and/or your shift linkage components are worn out our misadjusted, you will get clashing gears also.
First gear is not synchronized, so it will grind if the truck is even slightly rolling. If second is clashing, but third is not, I would check the clutch and linkage out.
Before you spend time and money on expensive and difficult transmission repairs, make sure everything else is in correct working order.
This includes the clutch adjustments (make sure it is not worn out), properly functioning Z-bar, proper transmission lube and fill, tight linkage and the like.
Good luck!
Old May 22, 2004 | 07:58 AM
FordBoypete's Avatar
FordBoypete
handX2
Your 3X Trans problem might be related to the droplets in your instrument cluster.
I see you didn't reply to that post yet, did you read it?
FBp
Old May 22, 2004 | 08:23 AM
handx2's Avatar
handx2
thanks fbp,i did read the other post i just haven`t replied yet.could you tell me where the vent hole is at so i can check it.what else do i need to do?do i need to change the fluid?does it have a filter?what kind of fluid do i use?
Old May 22, 2004 | 01:24 PM
banjopicker66
Handx: There will be a square plug on the side of the transmission. Unscrew it, and stick your little finder inside. If you can touch fluid with the tip of your finger, it is full enough.
To change it, unscrew the plug on the bottom, and drain it. To fill it, use 80-90W gear oil, and you will find a pumper VERY useful. Fill it until it just comes to the top of the fill hole in the side.
Hope this helps!
Old May 22, 2004 | 04:51 PM
JSMConstruction
Lightbulb
i would sugest a tranny fluid drian and a flush out...
then I would fill it up useing 85w-140 or 80w-140 gear lube but i wouldn't go any thinner then 80w-90...
