Sponsored by: Real Truck
Which fuse?
Old May 20, 2004 | 08:09 PM
Bob21262's Avatar
Bob21262
Question Which fuse?
Well I just purchased my 99SD CC to pull my new 5th wheel around. When I went to replace the existing trailer brake controller, I snipped the positive wire from the harness and grounded it against the frame. Didn't think it would be to big of a deal till I found out I had no owner's manual. I went thru every fuse (I think) but they all check out, unless I missed it.
Anyone have an idea of where to look?
Thanks ahead of time!!!!!1
Old May 20, 2004 | 08:13 PM
RJB1's Avatar
RJB1
Did you look under the hood? I thought they were near the fender on the drivers side.
Hope this helps.
Old May 20, 2004 | 09:03 PM
Bob21262's Avatar
Bob21262
Yes, Checked the ones under the hood and under the dash.
Old May 22, 2004 | 07:53 AM
joedepilot's Avatar
joedepilot
fuses
if i remember right there is a smaller fuse box underhood driver side near firewall. joe
Old May 22, 2004 | 08:09 AM
KenB's Avatar
KenB
Am I reading this correctly, You've grounded a hot wire?
Old May 22, 2004 | 11:40 PM
firebiz16's Avatar
firebiz16
The brake controller itself may have a fuse in it, have you checked for this?
Old May 23, 2004 | 10:17 AM
Bob21262's Avatar
Bob21262
I ran a new hot lead to the new controller and it works just fine. So somewhere on the truck is a fuse or relay that is blown.
