Sponsored by: Auxito
Ping
Old May 20, 2004 | 07:26 PM
jbm's Avatar
jbm
Ping
I know that there has been a number of threads about this subject but I was hoping someone could give me a summary on what was found best to solve this problem.
1998 F150 4.6 NASCAR edition.
Pings at 3\4 to Full Throttle
Pings more in A'C Mode
Pings less with 93 Octane
Pings even less with Octane Booster
Running Autolite APP104 Double Platnium 10K on plugs. Do I have the right plugs anyone?
K&N Air
Chip has been reprogramed by past owner. ( I think this is the problem)
Thanks
Old May 20, 2004 | 08:44 PM
03f150man's Avatar
03f150man
clean your mass air flow (MAF) sensor. Especially if you are running a nonfactory air intake system. your truck should not ping even with 87 regular.
Old May 21, 2004 | 01:08 PM
LxMan1's Avatar
LxMan1
If it has been set up for 93 octane by the previous owner with a chip, it will pimg on 87 or 89 octane.
I too would try cleaning the MAF and changing the fuel filter. it may be cloged just enough to restrict fuel at higher rpms and cause it to lean out.
Old May 22, 2004 | 01:12 PM
jbm's Avatar
jbm
Ping Fixed
The problem was number 4 plug wire was bad. The MIL did not pick it up until later on after a hard run. PO304 Error Code. I replaced the wire and it runs like a champ now. I have had 3 similar problems with wires on this truck. I put a new set of Beldins on about 10K ago and have had to replace 2 of the wires.
Old May 23, 2004 | 12:08 AM
LxMan1's Avatar
LxMan1
I would install a good set of Motorcraft replacement wires. They seem to do better.
bullit340
Sep 9, 2007 09:06 AM
MPDano
15
Nov 22, 2006 06:41 PM
captmoto
1997 - 2003 F150
Apr 23, 2004 06:46 PM
rcr
13
Jun 19, 2003 12:04 AM
