Speed Control Device
Old May 20, 2004 | 04:38 PM
graysondenmark's Avatar
graysondenmark
I am a new owner of a 2 wheel drive Ford Ranger Edge Pickup with 3.0 v-6 engine and it is a 5 speed. I noticed one day while I was "pushing" the truck that when I got to 90 MPH that the truck would do this little hesitation. It never stopped or anything but as long as I tried to 90 it would do this. As soon as I dropped to about 85MPH it would run fine with no heistations at all. I mention thsi to a froend of mine and they said that it may be some type of speed control chip on the truck that prevents it from doing 90 or better. I would like to know if this is true and if it is. Is there anything that I can do to remove it. I thank you in advance for your help.
Old May 20, 2004 | 05:24 PM
Dave257's Avatar
Dave257
Yep its true, only way I have heard that MIGHT take it off is a custom chip. $200-400 bucks..
Dave
Old May 20, 2004 | 05:25 PM
87 XLT's Avatar
87 XLT
Get an aftermarket performance chip if you really need higher RPM's
Old May 20, 2004 | 05:50 PM
maticuno's Avatar
maticuno
With that engine you are going to be wanting more power out of it anyway, so a Diablo performance chip would be a great investment.
Old May 20, 2004 | 05:52 PM
Vin 95's Avatar
Vin 95
Dont expect your engine to last long after this mod,running it at those high RPM's will take its toll on the rings and valve guides and seals.It wont be long befor its smoking and using oil.
Old May 20, 2004 | 07:32 PM
valo's Avatar
valo
Don't try to force it over 90mph. I read a thread here not to long ago someone doing that and screwed up his computer. I have a 4.0 sohc it does the samething at 90. So i try to never go over 85
Old May 21, 2004 | 09:59 AM
graysondenmark
Dave
Thank you Dave for the info. Be Blessed!
Old May 21, 2004 | 10:00 AM
graysondenmark
Thanks maticuno! Be Blessed!
Old May 21, 2004 | 10:04 AM
graysondenmark
Thanks Valo. did this person have the modified chip in it that allows it to go over 90 or did he just push it? Just courious.
Old May 21, 2004 | 06:31 PM
Ken00's Avatar
Ken00
In most cases the chip can be programed by the seller to remove the limiter, you can't change it.
Old May 21, 2004 | 07:33 PM
valo's Avatar
valo
no ,this guy did not have a chip he just tried to force it.85mph is prety fast. there realy is no need to go over 90mph. Just my opinion
Old May 22, 2004 | 01:04 AM
maticuno's Avatar
maticuno
About the 90 being high RPM...it's really not that much. I think once I pop it into 5th I'm only pulling about 3500 RPM's. Maybe I'm just used to that being low because I've always owned OHC 4 poppers.
