fuel gauge dilema
Old May 20, 2004 | 04:15 PM
conga man's Avatar
conga man
fuel gauge dilema
I have a 87 E150 conversion van and the fuel gauge dosen't work on either tank it switches fine but won't register,can someone help me? thanx conga man
Old May 21, 2004 | 06:58 PM
LxMan1's Avatar
LxMan1
Hi and welcome to the forum.
Well you could have a bad gauge or possibly 2 bad sending units. Are all of the other gauges working properly?
Old May 22, 2004 | 10:10 AM
conga man's Avatar
conga man
hi the gauge tested good but would both senders go out at the same time? All other gauges working fine.
Old May 22, 2004 | 11:49 PM
LxMan1's Avatar
LxMan1
I wonder if the switch that you use to switch tanks is bad on the gauge side. It may be switching tanks, but not letting voltage thru for the gauge.
Old May 24, 2004 | 09:54 PM
Muddr Trukkr's Avatar
Muddr Trukkr
its your sending unit, from gettin sediment inside the meter, or just worn out, after all its 17 years old. and yes its both of them, mine both did the same thing on my 88 f150. about 75 - 90 bucks will get you a new one. before mine went out they were bobbing around on my gauge like a jack rabbit, then just stopped responding. not a big job to fix those though. good luck.
bjmbjm1998
Escape & Escape Hybrid
Jul 14, 2012 10:15 PM
Rush117
2011 - 2019 Explorer
Mar 11, 2012 10:40 PM
conga B
16
Feb 10, 2011 02:50 PM
aerocolorado
May 16, 2010 11:57 PM
vaman4215
26
Jun 26, 2008 06:39 PM
