Sagging Sunvisors
Old May 20, 2004 | 10:10 AM
Kliphton's Avatar
Kliphton
Sagging Sunvisors
Have any of you guys come across a fix for sagging sunvisors? The bracket holding the sunvisors up in my '84 F-250 seem worn out. Is there an easy fix, or does anyone know where to get new brackets?
Old May 20, 2004 | 01:22 PM
tsc's Avatar
tsc
Check out the local scrap yards for a cheap replacement
Old May 20, 2004 | 09:03 PM
ditch witch's Avatar
ditch witch
At a later date the design changed a little. I replaced the headliner in my '84 with one out of a '91 (I think it was). I also replaced the sun visors. The visors mount in the corners exactly the same, however the inside (near the rear view mirror) had a plastic clip to hold the end in on the newer model. But either way, your local "recycler" will have some.
Old May 21, 2004 | 07:20 AM
Kliphton's Avatar
Kliphton
Thank you ditch witch. That's the kind of info I was after. You rock!!!
Old May 21, 2004 | 09:19 PM
Spectramac's Avatar
Spectramac
My '87 has the improved sunvisors (with the snap on end supports). My Dad has an '86, his are the old floppy visors.
Old May 22, 2004 | 07:17 AM
Kliphton's Avatar
Kliphton
I was able to find a set at a local "Pick and Pull" out of a '91 F-150. Excellent shape, exact color I nedded (well close enough). All I had to do was drill four extra holes to hold the snaps. Easy install. Excellent upgrade modification, and very affordable at only ten dollars for the set. Now I'm looking for a seat.
klachaine
Dec 2, 2014 11:42 AM
beetle
Jul 2, 2007 08:08 AM
RMS94
Jan 11, 2007 06:36 PM
snipa
Jan 4, 2005 10:21 PM
Midnite Cruiser
Feb 22, 2003 10:37 PM
