Low Mileage Interval Oil Changes vs Brand
Hey Y'all:
I'm doing oil changes on 4 vehicles that mostly sit quietly parked. They are as follows:
1985 Ford Econonline 350 Diesel Bus (64k = 3400 miles per year).
1991 Ford Econoline Van (68k = 5200 miles per year).
Pair of 2000 Ford Econoline Vans Trition V8 (22k = 5500 miles per year).
The Bus gets driven about town on Sundays mainly. The old van gets local use. The two newer vans also mainly local trips w/ an occasional road trip. Based on the low miles, I'm doing oil changes at 3 months. I am considering switching from using name brand oil such as Shell, Castrol to economy grade oil such as Unical-Coastal / Advance to save money. So far my research has shown that there on only minor differences in the VI, Pour point, ash %, and zinc% between all the major/minor brand names. Any thoughts/ideas?
Thanks!
P.S. I like being able to practically stand up under the van to change the oil vs my car which seems only about 1/16 of an inch off the ground....
Thanks!
Go to the cheapest API SJ/SL (gasser) CH-4/CI-4 (diesel) oil that you can find and change oil/filter twice per year.
With those miles you might be able to get by changing only once per year, but it sounds like you do a lot of short trips that do not get you oil hot. You might get more sludge build up than you want changing only once per year.
