Sponsored by: Innova
sub comparison
Old May 19, 2004 | 07:02 AM
awf-150's Avatar
awf-150
sub comparison
sub A ~ sub B
max power (coils in series) ~ 400w ~ 600w
cont. power " " ~ 200w ~ 300w
SPL (coils in series) ~ 85.3dB ~ 82dB
freq. Response ~ 20 Hz-1.5kHz~ 20Hz-2.0kHz
cone mtrl ~ polypropylene w/titanium~ glass fiber
woofer magnet~ strontium ferrite 33oz ~ strontium Ferrite 62 oz.
woofer basket ~ stamped steel ~ Aluminum
cone surround mtrl ~ NBR Rubber ~ Rubber
outside dia. ~ 10 1/8" ~ 10"
mounting hole ~ 230.2mm ~ 231mm
mounting depth ~ 127mm ~ 135mm
sensitivity~ 82.3/85.3 ~82dB
max peak music ~ 400w ~ 600w
cont power ~ 200w ~ 300w
nominal impedence ~4/8 ohms~ 4 + 4 ohm
Re DC Imp. (+-10%) ~ 3.3/6.4 ohms~ 7 ohm in series
Le ~ 1.05/4.44mH ~ 2.34/5.79mH
V.C. Dia. ~ 50.8mm ~50.8
Sd ~ .0366msquared ~ .0333msquared
Vas ~ 26.13 L ~24.9578L (paralleled)
Fs ~ 41.6 Hz ~ 32.2463 Hz
Qts ~ 1.38/.76 ~.5316 (paralleled)
Qes ~ 1.58/.78 ~ .6261 (paralleled)
Mms ~ 105.4g ~ 151.3986g (paralleled)
Mmd ~ 101.4g ~147.9547g (paralleled)
Rms~ 3.44kg/s ~8.7056?m (paralleled)
Bl ~ 7.2/14.6 Tm ~18.51Tm (paralleled)
Speaker displacement~ 140"cubed(R)/105"cubed(F)~ .0333msquared
Xmax~ 9.2mm ~ 7.5mm
Magnet weight~ 33 oz. ~ 62oz.
Apparently subB if far superior for loudness and quality over subA, to me they look the same??? can anyone decipher this info for me???? Also does anyone know any other brands that will be much better than these numbers,without having to go say more than 1 cubic foot sealed??
Old May 19, 2004 | 11:55 AM
88beater's Avatar
88beater
Well a few things I noticed is that speaker B can handle more power, which when you start turning up the volume, if your not pushing the max power rating on the sub, the speaker sounds better. (like same amp at the same volume...sub B can handle it easier) Also, Sub B has a much larger magnet, I do know that the magnet has a decent amount of importance as to the sound quality of hte sub and the power rating.
Just my 2 cents...
Old May 22, 2004 | 10:47 PM
Prowler_3's Avatar
Prowler_3
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Size</TD><TD align=middle bgColor=#efefef>10 inch</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Type</TD><TD align=middle bgColor=#c0c0c0>Woofer</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Voice coil</TD><TD align=middle bgColor=#efefef>Configuration - Dual
Material - Aluminum
Description -
3"
</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Cone Material</TD><TD align=middle bgColor=#c0c0c0>Metal -
Anodized Aluminum Parabolic
</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Frame Material</TD><TD align=middle bgColor=#efefef>Frame - Cast
Material - Aluminum
</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Surround Material</TD><TD align=middle bgColor=#c0c0c0>Rubber
Description -
Thermoplastic
</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Spider</TD><TD align=middle bgColor=#efefef></TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Crossover</TD><TD align=middle bgColor=#c0c0c0></TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Specifications</TD><TD align=middle bgColor=#efefef>Power handling(RMS) - 1000 Watts
Power handling(Peak) - 2000 Watts
Impedance - 4 Ohms
</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Dimensions</TD><TD align=middle bgColor=#c0c0c0>Depth Bottom mount - 7.8 in.
Cutout - 9.19 in.
Magnet weight - 192 oz.
</TD></TR><TR><TD vAlign=top align=left width=150 bgColor=#ffffff>Enclosure</TD><TD align=middle bgColor=#efefef>Ported box -
Recommended Volume (Cubic feet) - 1.25
F3(Hz) - 35
Rocford T210D4......
</TD></TR></TBODY></TABLE><!--include file="inc_detail_links.asp"-->
