battery discharges when ignition is off
I own a 79 f100, 351m c6. In the last 24 hours the battery has totally discharged 3 times. After the 1st two times I changed batteries to a new one from my f250, same problem, after about 4 hours it is so dead it doesn't even illuminate the oil light when the key is turned on. Nothing obvious left on, brake light etc not activating (had that happen once before). Where do I begin checking the system for this power sapping ghost.
Thanks in advance
Thanks in advance
Originally Posted by 87 XLT
Connect a 12 volt test lamp between the negative batery cable & batery post and pull fuses until the light goes out. Make sure everything is turned off including the dome light.
540milotalon
08-15-2016 11:31 AM
F350dog
21
12-23-2015 05:37 PM
ford f-200
Electrical Systems/Wiring
01-20-2009 04:46 PM
gearloose1
1999 to 2016 Super Duty
11-19-2007 09:07 PM
