Tire Size
Old May 18, 2004 | 09:46 PM
BCBen's Avatar
BCBen
Tire Size
Hey all. I have a 2002 F250 Super Duty. I need to replace the tires and I'm thinking of buying larger than stock. I have two questions:
What is the largest tire that can go on an '02F250 without any rubbing?
Other than odometer/final drive gearing, what negative issues exist?
Also, any thoughts in general about changing tire size?
Old May 19, 2004 | 08:58 AM
1960Airstream's Avatar
1960Airstream
I don't know if this will help but I have an F250 4x2 crew 7.3. I just installed Michelin LTX 285/75 16's on it. Great ....no fantastic tires and no clearance problems at all. Discount Tire did say that on some Superduties they have to trim a piece of the rear mudguard on the front wheelwells. Luckily they didn't have to do it on mine. As far as the speedometer. My truck ran 3-4 mph slow.....speedo says 65 road speed was 62. I verified this with my GPS software. I haven't tested it yet with the new tires but I should be right on now with the speedometer based on Michelins spec numbers. Good luck on your purchase.
Old May 19, 2004 | 07:58 PM
BCBen's Avatar
BCBen
Thanks for the reply. I'm not looking for extreme ground clearance changes, just to maximize what's avalable in stock trim. Mine's a 4X4, and I am off paved road most weekends fishing, so any little increase in clearance gives peace of mind. I take it from your handle that you have a classic silver bullet. If you ever haul it up British Columbia way, email me and I'll scope out the best places to stay/things to do.
Old May 20, 2004 | 03:37 AM
Quadzilla's Avatar
Quadzilla
My truck is the older body style, so this might not help too much, but I had 35" tires on mine before I lifted the front end, and all that needed to be done was to shim the front bumper about 1" for clearance. Had I used 33" tires, there wouldn't have been any issue at all.
Old May 20, 2004 | 06:49 AM
Skeetshooter's Avatar
Skeetshooter
I have the Geolanders in 287/75's and I have no issues. My friend has BFG 295/75's on his and he clears the inner fender without problem's. Best of luck with your choice.. Jeff in NM...OUT
Old May 20, 2004 | 02:39 PM
PWRSTRKN4X4's Avatar
PWRSTRKN4X4
Talking
I did alot of research on tires for my 99 F-250 4x4 PSD and came up with one tire that I am really impressed with. The tires are the Mickey Thompson Mtx Radials in 285-75r-16's. They fit just right with no rubbing at all. I got them from National Tire and Wheel and get a really good price on them. When I called them I got free shipping also.
