hot start problem
Old May 18, 2004 | 08:28 PM
tennessee's Avatar
tennessee
hot start problem
helping a friend with a 1991 f150, 300-6, 5spd. truck has about 146,000 mi. truck cold starts well, but if it has been run to operating temperature and shut off, truck will not start. if allowed to cool about 30 min. truck starts. while hot truck turns over slow almost like with a dead battery. starter was recently replaced, and the charging system checked out fine at that time. truck will start if jumped off. any ideas? i noticed that the exhaust pipe is close to the starter, would this cause the starter to overheat and drag? any help would be appreciated. trying to do the work ourselves as he is a teenager on a budget.
thanks, mike
Old May 18, 2004 | 10:44 PM
Slade901's Avatar
Slade901
Try this starter heat shield.
http://www.jegs.com/cgi-bin/ncommerc...57&prmenbr=361
You might want to disconnect the battery cables and ground cables and clean them up and then tighten them up.
Your battery might be getting weak. Have this battery check at Autozone or Advance Autoparts.
