1978 - 1996 Big Bronco
transmission question/ c-6
Old May 18, 2004 | 04:06 PM
hstormn's Avatar
hstormn
i bought a 82 bronco 302, it runs awesome and is in top shape it has 160000 on it factory paint still shines. sweet 82. well any way when the truck is cold it does not want to go into drive, but it goes right into rev. if i rev it it will go. it only does this when it cold,no slippage or anyother signs of a bad tranny. when it is warm no probs at all. any ideas please help. hope it is simple oh i changed the fluid and filter already.
Old May 18, 2004 | 08:56 PM
tygarcia's Avatar
tygarcia
I have the exact same truck and till now never noticed that my truck does the exact same thing. let me know what you find out
Old May 19, 2004 | 12:08 AM
hstormn's Avatar
hstormn
i cant take off in drive until it is warmed up without revving the **** out of it to get it to engage. warmed up absolutely no probs
i dont get it
Old May 19, 2004 | 09:33 AM
Breeze's Avatar
Breeze
Slippage when cold is usually indicative of a worn transmission, theres just enough excessive clearances inside the tranny that it will slip, but due to heat expansion when things warm up, it works fine (however, an excessive load on it would probably cause slippage, even when warm) for now if it seems to drive fine when warm, you should be ok, but you will probably need to overhaul the tranny eventually. How soon will likely depend on how hard you drive it.
Old May 19, 2004 | 08:12 PM
hstormn's Avatar
hstormn
cost
about what is the normal cost to rebuild the c-6? in the truck and out of the truck. is it difficult? should a proffessional do it?i am able to build a motor but never fooled with a tranny besides swapping them.
