t-case clunking
Old May 18, 2004 | 03:32 PM
natron343's Avatar
natron343
t-case clunking
91' F-150 XLT 4X4 5.0. clunking and sqwealing coming from t-case. case moves with every "clunk".
front shaft is also turning when not in 4w. 4w work fine, hi/lo, trany works fine also. noticed some splatters under neath truck. maybe leaked fluid, seized bearing?
Old May 18, 2004 | 05:07 PM
FordPerf300's Avatar
FordPerf300
Sounds like your tcase is about toasted, i would pull it apart and inspect the inside, check oil pump for wear, bad bearings, stretched chain.
