Stock exhaust manifolds (plan on upgrading to headers in the future) feeding a dual 2.5" exhaust (no H-pipe) with Flowmaster mufflers
3-speed manual transmission with overdrive
The car is not raced (except maybe the occasional stoplight) and is mainly used for weekend trips and cruising.
They recommended the 750 cfm Speed Demon. I think that may be too much carb for a street driven engine and that a 650 cfm Speed Demon would be more appropriate. The engine has just a slight lope with the cam I have installed. What do you all recommend? I am pretty much settled on a Demon (don't like the looks of the Edelbrock, Holley is OK). Thanks.
first of all it has proven that edels have more power, relaibleity, and better air/fuel miture than the holleys. but if you inist on spending the money than i would definlty go with the 650fm carb over the 750 is to much.
I think you may be jumping to conclusions here, I think you've got it backwards. The air/fuel mixture may be a little more consistent, but the reliability and power definately go to holley.
I'd think a simple Holley 650cfm vacuum secondary would work great. No need to spend the $$$ on a demon.
Even looking at the Barry Grant site, that seems like a big carb for your application. That's the same carb they reccomended for my 446 with a 228at50 duration cam.
I think the 575 or 650 is adequate. You might even be able to use one of their mor affordable Jr. carbs.
the BG carbs tend to flow better than labeled.
here is a Jr. part number that fits the description to your app.
Part # 6402020 VFE
725 Road Demon Jr with Ford kickdown linkage and optional electric choke
Stock or Mild performance applications with 383-409 CID V8 engines
first of all it has proven that edels have more power, relaibleity, and better air/fuel miture than the holleys. .
Uh huh. Thats why everybody races with holley & bg carbs (which is just an advanced holley) instead of edlelbrocks
Greg is indeed correct that the Demons flow at higher capacities than the other brands at the same advertised volume, due to they way they are measured. The long and the short of it is that you would indeed be fine with a 650. I'm not a big fan of the jr.s, but at this point in your combo it would be a good match for your current setup. If you ever plan on expanding on your build I'd go for the 650 sd to give you room to grow.
I don't recall. I would have to pull out the paperwork. The engine came from S&S Auto Engine Remanufacturing (http://www.rebuilt-auto-engines.com/ford-engines.html) out of Spokane, Washington. It is whatever they install as the next step up over a stock cam.
Just wondering because it seems similar to my mtf-4 melling cam in my 390.
adv 282/292
204/214
valve lift .484
.510
ls 112
centerline int 107/ex 117
power range 1200-4700
acctually most people with daily drivers and raers use edelbrocks. holley is good but EVERYONE ive talked to incuding people on this forum have said after using both brands the edels are way better.
I agree the edelbrock is a better street carb. Its smoother, idles better and performs well but a decent tuned holley will make more power.
i have a 74 f-100 with a 390, mine is built up slighty but i was running a 600 holley then i put on a 750 holley, both were vac sec. the 750 didn't seem to do anymore then the 600. soooo, i went to my local speedshop and they recommended a demon 750 mech sec. BOY what a difference !!!!! i never thought a carb could do such things !!! don't be worried about tuning the demon either, same as a holley and most parts are the same. i love laughing a rice rockets now !!! they never knew what hit em !!!
