Ammeter question from a Tech article
Old May 17, 2004 | 09:56 PM
GeneStoner's Avatar
GeneStoner
Explain this...
In Jim Barbera's tech article on this board:
https://www.ford-trucks.com/articles/ammeter.php
He states the following--
"These are the voltages you should see under the following conditions.
Headlights on, engine off -.032
Ignition Key on, engine off -.027 (with electric fuel pump running)
Ignition key ACC -.002
Engine on +.2
Engine on after a few minutes +.1 "
Then he goes onto say in the very next sentence:
"If you see those voltages, the gauge is bad..."
Which is it, I don't get it. Should you or should you NOT see those voltages under the stated conditions on a working gauge?
Old May 17, 2004 | 10:04 PM
vox's Avatar
vox
I believe what he is saying is that if you get those readings, and your gauge is not moving. Then your gauge is bad.
Just my thought.
Old May 17, 2004 | 10:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
IMO vox is correct.
Old May 18, 2004 | 07:00 AM
76supercab2's Avatar
76supercab2
I fixed mine by modifying the shunt he mentions in the article. I think that most ammeter problems are caused by a shunt with incorrect resistance value.
