Sponsored by: Kumho
King pins?
Old May 17, 2004 | 07:50 PM
yoda's Avatar
yoda
King pins?
My uncle ask me too clean-fix the king pins(steering part?) on his 198? F350
4X2 DRW and I dont know what king pins are help ME.
Old May 17, 2004 | 07:53 PM
j wright's Avatar
j wright
King Pins are what the front hubs rotate on, moved by the tie rods. Hope that helps!!
Old May 18, 2004 | 03:58 PM
yoda's Avatar
yoda
How do I rebuild them etc.
Old May 19, 2004 | 12:42 AM
j wright's Avatar
j wright
I did an old C****y and what I did on that was to buy and over size pin and hone out the knuckle....but I think I would check out chilton's manuals or something like that..If you don't have one check out Library,,,GOOD LUCK let us know how it works out.
John
Old May 19, 2004 | 04:48 AM
rebocardo's Avatar
rebocardo
Does the truck have king pins or ball joints? On a 2x4 I think it might be ball joints. If it is king pins the way to fix them is to remove the bushing and replace it with another one, usually metal or composite. Since you are asking, it might be better if you took it to a machine shop. If you have ball joints, it is a doable job by yourself.
