"97" Ranger Codes
Old May 17, 2004 | 06:45 PM
rfrench1's Avatar
rfrench1
Question "97" Ranger Codes
I have a "97" Ranger 4x4 4.0. Recently I have had the check engine light come on after a long trip (300mi) at about 80mph. This has happened numerous times but I just got it to AutoZone when the light was on. The light would go off after a short time of city driving. The codes that AuotZone pulled was P1131 & P1151 which indicated to check with the original manufactuer for the results. Does anyone know what these codes indicate?
Old May 17, 2004 | 07:01 PM
BassGuy's Avatar
BassGuy
Go here.
http://rockledge.home.comcast.net/Ra...llery/DTCs.pdf
Old May 17, 2004 | 07:51 PM
rfrench1's Avatar
rfrench1
Thanks It appears I have o2 sensor bad. Can't tell whitch one. Should I replace all 3?
Old May 17, 2004 | 08:17 PM
Ken00's Avatar
Ken00
I would recommend going through the list of possible causes under the P1130 code. If you do replace them only do the front ones, the one behind the cat is only a monitor.
