I have a 1976 hi boy with the power assist steering link. How hard is it to convert it to standard power steering and if so where are the kits / parts avalible?????
do a search on this..its been discussed a gazillion times...However, apperantly there is a kit on e-bay to do this..dont know how much it is, or how good it is..Im mid way thru my conversion..using a box from a 1 ton van..had to box the frame to mount it...so far so good...
The Ebay kit is great from the talk on these forums but at almost $1000 it is too much for me. I would rather peice together my own kit. Although the kit on ebay is all bolt on IIRC. Depends on how good you are with a welder. If you can weld then get the parts from a junk yard or parts store and read the how-to in the tech articles. You may be able to save a few $$'s. Just my $.02
Dieingford, I agree, Ive been scrounging or making parts for this swap for a while...Ive got hardly any $$$ into it. The only thing Ill prob buy new will be a pump. Cheap enough and a little piece of mind...
That's the next project after my 446 stroker with a 8-71 blower is finished. How much do you have into it if you don't mind me asking. I will be getting a new pump also but using used parts for the rest I think.
Got the box from a buddy for $25. and a piece of Alum treadplate I had laying around..thats all so far..havent priced a pump yet, but will prob go with remanufactured...
78-79 f250 4x4 steering box,narrow the frame slightly, box it,trim inner fender
drill holes to mount box,build new steering link,buy new steering shaft from www.borgeson.com, enjoy having real power steering
