86 Bronco Sending Unit
Old May 17, 2004 | 02:35 PM
ChargerFan's Avatar
ChargerFan
Anyone know if a sending unit from an 87 Bronco will work in an 86? I've pulled the 87 out and have my first one from the 86 to compare. They sure look the same. Wires all run to same terminals, connectors, length...I have heard that the resistance in the potentiometer was reversed somewhere around these years so my gauge might not work or work backwards(?) Will the gauge out of the 87 swap in? Any help out there? Thanks
Old May 19, 2004 | 04:22 PM
LxMan1's Avatar
LxMan1
Well physically it is the same, not sure on the sending unit. I would use an ohm meter on the sending unit terminals to see if they act the same as you move the float arm up and down.
Old May 19, 2004 | 04:32 PM
ChargerFan's Avatar
ChargerFan
I'll give it a try. Thank you
crazed87bronco
Oct 21, 2010 01:54 AM
den7bronco1
1978 - 1996 Big Bronco
Oct 28, 2009 01:06 AM
den7bronco1
Jan 25, 2009 10:46 PM
den7bronco1
Jan 25, 2009 08:13 AM
weswes01
Oct 28, 2007 05:34 PM
