Sponsored by: Real Truck
Transmission Problem
Old May 17, 2004 | 01:11 PM
jj9539's Avatar
jj9539
I purchased an 04 King Ranch F250 6.0 about 2 months ago. At approximately 1700 miles I installed the Edge Juice module with attitude. At approximately 2500 miles I started experiencing some problems with the truck shifting into reverse. It would take several seconds to engage in reverse. I took it in and they replaced a solenoid valve in the tranny. I brought it home and in 2 days it was doing it again only worse. It is also now affecting the forward gears.
Has anyone else had this problem or know anything about it.
Other than this issue the truck is absolutely awesome. I am looking forward to getting this worked out.
Old May 17, 2004 | 02:42 PM
blackthorne2's Avatar
blackthorne2
Talking Wrong Forum
Wrong Forum brother. You need to post this in a specific section...look through all the forums and you will see one that matches your truck. Look in the SuperDuty/Heavy Duty Area
Old May 17, 2004 | 03:16 PM
jj9539's Avatar
jj9539
just figured that out and put it there. Could not figure out how to delete it.
Old May 17, 2004 | 03:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Use the red triangle with the "!" to alert the moderator.
Old May 17, 2004 | 10:54 PM
lowet's Avatar
lowet
easy fix, they need to get you a solenoid valve with a newer build date, your ford svc. dep. should be aware of this exact date of build on the valve, the newer build date valves are built to a different spec. my budd just had 2 put in his 04 an older build date one that failed also, and then a newer one that works just fine, the new one came from Washington state....only one they could find.
