Gilbco2000
Old May 17, 2004 | 11:52 AM
Gilbco2000's Avatar
Gilbco2000
Red face Gilbco2000
I have recently built a 390 fe engine, my machine shop bored the block.060. I bought a 428 crank had it turned .010, 428 rods. .060 pistons and a mild cam, stock rebuilt dist. Could some one please explain to me the best way to set overall timing and initial tuning.
also, I am putting this in a 76 highboy that had a serious electrical fire in the ign system. I have factory wiring scamatic but would like to get advice on the best electrical Ignition, coil and spark set up if any one cares to help????
Thanks
Old May 17, 2004 | 01:10 PM
dieingford's Avatar
dieingford
I had a MSD in my Chebby and didn't notice any difference over the HEI it had. I have heard great things about the DUI. The DUI is also a single wire hook up. I'm all about one wire hook ups. Alt. and soon the DUI if it fits with a blower. Just my $.02
Old May 17, 2004 | 01:33 PM
gtex's Avatar
gtex
Count another nomination for the DUI. It is wahat I would do if starting from scratch.
http://www.performancedistributors.com/forddui.htm
If that's a bit too much for the budget, consider the Duraspark from a late 70s truck.
Old May 17, 2004 | 03:19 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well All I can say..is what I have read about the DUI (Davis Unified Ignition)
Has been all Good....And that will be the one that I go with for my build (in process)
It doesnt have multi spark like some units...But it throws out 50,000 volts to the plugs... And Like said above The 1 wire hook up...keeps the engine compartment
Looking clean....About $375... Good luck -Russ
