open door light
Old Jan 23, 2002 | 11:06 AM
mkb1314's Avatar
mkb1314
open door light
Old Jan 24, 2002 | 09:00 PM
tiwood's Avatar
tiwood
Post open door light
I HAVE A 99 F250 CREW CAB WITH A CONSTANT OPEN DOOR LIGHT ON THE DASH. BECAUSE OF THIS THE INTERIOR LIGHT STAYS ON ALL THE TIME AND I HAD TO PULL THE FUSE. WHERE ARE THE DOOR SWITCHES AND HOW DO I GET TO THEM? THERE ARE NO PUSH SWITCHES LIKE THE OLDER TRUCKS AND MY SERVICE MANUAL DOSN'T SHOW THEM. PLEASE HELP. THANKS, TIM
Old Jan 24, 2002 | 11:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
open door light
[updated:LAST EDITED ON 25-Jan-02 AT 00:06 AM (EST)]>I HAVE A 99 F250 CREW CAB WITH A CONSTANT OPEN DOOR LIGHT ON
The switch that activates the lights and door ajar light is an intergral part of the latching mechanism. You'll have to remove the door panel to inspect for loose connections. I'm sure once you remove the panel there has to be some mechanical device on the mechanism that actuates a switch. That could be the culprit, also.
Bet ya wish you had a regular cab right about now!
Old Jan 25, 2002 | 06:59 AM
tiwood's Avatar
tiwood
open door light
This is a minor problem, no I am very happy with the crew cab.
Old Jan 25, 2002 | 08:56 AM
spartamouse1's Avatar
spartamouse1
open door light
the dome light switches are on the door latch inside the door. will bet you several beers that is your problem. if you take thw seitches out and lub them they will work again but i would put new ones on if i had them off.
parts man
Old Jan 25, 2002 | 09:18 AM
To D Lake's Avatar
To D Lake
open door light
Same thing happened to my SD. Take a can of WD40 and spray liberally into ALL door latches. Open and close doors several times. This should do the trick. Has kept my "door is a jar" light out for the better part of a year. If this doesn't work, I've been told that replacing the switch is fairly easy and inexpensive. Try the WD40 trick first.
Robb
Old Jan 25, 2002 | 11:32 AM
wildjon300ci's Avatar
wildjon300ci
open door light
Same thing is happening to my dad's F-350 Crew. THe WD-40 trick doesn't work and the dealer stopped it once under warrenty. It started happening again so my dad took it back. They fixed it which worked for 2 days and then It's happening again. He's gonna take it back in and make them fix it soon.
