AC goes warm
Old May 16, 2004 | 10:11 AM
mgdemarco's Avatar
mgdemarco
AC goes warm
I have a 1991 f-150 with the 5.0 engine. The AC stays cold for about 20 minutes then it goes warm. It comes back cold after being off for a minute. Whats wrong?
Old May 16, 2004 | 10:31 AM
fordborn's Avatar
fordborn
sounds like you are low on freon.
Old May 16, 2004 | 10:54 AM
Stokes's Avatar
Stokes
yep, time to get your system re-charged, for a 91 im amazed to hear it lasted this long!
Old May 16, 2004 | 11:03 AM
quaddriver's Avatar
quaddriver
have the clutch tested. when the system voltage drops (fan on high, brakelight on, at idle, in gear etc etc) the clutches have a lot of excessive clearance and the mag field can no longer hold it. the fix is to shim the clutch which can be done without a drain.
my 90 btw has finally run out of freon after 14 years....I am going to convert it to 134a
