installing headers
Old May 16, 2004 | 02:17 AM
toogaw's Avatar
toogaw
Question installing headers
just wondering, i ordered a set of hedman headers for my 79 f-100 stepside with manual transmission, and 302 Cid, anyone tell me of any problems they have had installing these or what i could be encountering? it is the original drivetrain, but wondering if the headers will clear the manual linkage or not. any help will vbe appriciated. thanks
Old May 16, 2004 | 11:26 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
I have installed that brand of headers many many times the drivers side is
the easy side the linkage will not be a problem ! The pass-side is very tight
you will need to losen the nut on pass-side motor mount and jack up the engine and once you get it high enuff it will fall in . Jegs sells a header hookup
that works very good.
P.S some 73-79 trucks have a brake line bracket that needs a little bit
sawed off the end .( drivers side not all have that bracket in the way) this is
mounted to the steering box.
Old May 17, 2004 | 07:47 AM
74f100's Avatar
74f100
Mine went in exactally as Pro-steet has said. I am having a problem with the collectors in the way of the shift linkage though. I normally leave the "flatter" side of the collector towards the ground. This caused the top side to have the "high" side that the linkage hits when pulling shifter into the first/reverse gate.
