Sponsored by: Real Truck
center bearing?
Old May 15, 2004 | 06:02 PM
nickdoni's Avatar
nickdoni
center bearing?
My 2001-cc,4x4,single rear wheel is making a funny noise.When im next to a guard rail or fence doing 20mph or more i can hear a rubbing noise.Kinda sounds like im riding the brakes.Brakes are fine by the way.I wa thinking it could be the center bearing.Anyone else had trouble with the center bearing?Ive got 54,000mi.
Old May 16, 2004 | 04:20 AM
m350's Avatar
m350
My 99' F-350 SC 9'dump had a bad u-joint with about 50k miles, I wondered the same thing about the center carrier bearing,,took the whole setup (drive shaft and center carrier) to a truck driveshaft shop,,they replaced u-joint, center carrier bearing was ok, and slip splines were ok too, just greased splines good, they added greasable u- joints, and balanced the shaft,,,like $ 275.00 seemed good afterthat,,,,,well then I traded the truck,,,LOL,,,,,,,Later,,,,,,,,Mark
Old Sep 1, 2004 | 09:28 AM
wildman52's Avatar
wildman52
nicdoni: Did you ever resolve your rubbing noise? I have a similar noise in my 2000 F250 4X4 crew at 90k. I have been told by one mechanic that the noise is comming from the transfer case ($1400 for a reman). I can very well imagine the noise initiating in the carrier bearing and radiating to the transfer case.
Old Sep 1, 2004 | 10:39 AM
Skavdog's Avatar
Skavdog
I had problems with my center carrier bearing as well. It went bad at 8,000 miles. Symptoms sound similar, an annoying squeal when I hit 20 mph. Anyway, replaced it and it solved everything.
Old Sep 1, 2004 | 12:23 PM
cwb's Avatar
cwb
Originally Posted by m350
like $ 275.00
You got hosed.
Old Sep 1, 2004 | 08:01 PM
nickdoni's Avatar
nickdoni
sorry for the late reply guys.Anyway,It was the center bearing.It costs 70$ from the dealer and it was simple to replace myself.
barthel
Aug 7, 2011 06:53 PM
mizzitch
Jan 13, 2011 08:55 PM
SunnySide
Nov 20, 2010 04:00 PM
mjxmahoney
Sep 23, 2009 07:41 PM
Lojack1
1983 - 2012 Ranger & B-Series
Nov 18, 2002 06:47 PM
