Oil Filter Question
Old Jan 27, 2002 | 02:37 AM
Roaring's Avatar
Roaring
Oil Filter Question
Old Jan 30, 2002 | 09:13 PM
choirman's Avatar
choirman
Oil Filter Question
I read the info on Oil Filters that has been talked about in the Oil & Lubrication board. After reading the filter research I pulled the Fram filter off my PSD and replaced it with a Motorcraft and cut open the Fram. I did not find a by-pass valve or anti siphon valve, am I missing something in the filter?
My question is " Do the Filters the PSD motors have or need these." On my diesel farm tractors they are located in the filter mounting.
I have not cut open the Motorcraft filter. I will at the next oil change.
The one odd thing I did find on the Fram filter was what looked like a blow out of a pleat in the filter medium. There was not a hole but it did protrude out from the rest of the filter.
The Motorcraft filter is also about an inch longer than the Fram. Possibly more filter material.
I have been using NAPA 15w 40 but am changing to Rotella on the next change.
Let's here what you think or know.
Old Jan 31, 2002 | 04:25 AM
alanscott's Avatar
alanscott
Oil Filter Question
The bypass valve is built into the filter base. Mine fell out once while I was changing the oil and I had to re-pean it into place. It looks like a flat washer and has a spring behind it. You can see it off to the side of the main oil passage into the oil filter. It was just luck that I saw something fall into the drain pan when I pulled the filter off.
alanscott
Old Jan 31, 2002 | 06:14 PM
The Diesel Dude's Avatar
The Diesel Dude
Oil Filter Question
You must have an older truck. The design has been changed. There is now a snap ring that holds it in -- a much better design.
