Towing Capacity
Old Jan 23, 2002 | 05:08 PM
Gr8ride's Avatar
Gr8ride
Towing Capacity
Hi,
I have a 93 F250 7.3l automatic.
I am looking at buying a gooseneck
flatbed, but first I need to now the
towing capacity of the truck.
Thanks,
Gr8ride
Old Jan 25, 2002 | 08:36 PM
tiwood's Avatar
tiwood
Towing Capacity
I have a 99 psd crewcab and the gearing of your truck will change things some. The gearing of my truck gives me a 10,000lb limit.
Old Jan 26, 2002 | 07:38 PM
Gr8ride's Avatar
Gr8ride
Towing Capacity
Is there a way to figure out
which rear end gear I have?
Old Jan 27, 2002 | 02:37 AM
Roaring's Avatar
Roaring
Towing Capacity
I have a 93 F250 S/cab 4x4 and have changed to 410 gears for towing a 7000 lb 5th wheel
the only troubles I have when towing is a lack of power in the hills.
I have had to have the tranny rebuilt once and replaced with a rebuilt another time.. there is 255,00km on the truck. The truck will tow have no fear...
Old Jan 27, 2002 | 12:27 PM
rotorhead's Avatar
rotorhead
Towing Capacity
gr8ride,
Under the rear of your truck, look for a little metal tag stuck under one of the bolts on the pumpkin on your rear end. It should have a series of numbers with either a space or an "L". I believe it's the first 3 numbers which refer to the differential of your setup. for example, a 3.73 rear would be printed 3 73 if it had an open rear, or
3L73 if it was a limited slip(the old posi-traction) rear. Hope this helps, and mostly I hope I'm right and this is what you're referring to!
rotorhead
Old Jan 28, 2002 | 08:47 AM
Gr8ride's Avatar
Gr8ride
Towing Capacity
Ok, I went out and looked and this is what I found.
S129G
10 10 2 3C 15
From what I can tell I have a 3.15 gear,
but what does the C stand for?
Does anyone else have a 3.15?
Thanks,
Gr8ride
Old Feb 1, 2002 | 12:30 AM
bhmadsen's Avatar
bhmadsen
Towing Capacity
I believe my 89 was 3.55 but I could be wrong. Have you checked in your owners manual for any info on max CGVW?
Your GVW will be on the data plate in the door jam. With these two numbers and the weight of your truck you should be able to figure out your maximum gross trailer/pin weight.
Old Feb 1, 2002 | 09:40 AM
MikeSmithFL's Avatar
MikeSmithFL
Post Towing Capacity
