Aerostar Ford Aerostar
Need wiring guide to cruize control
Old May 15, 2004 | 03:29 PM
shaun1979's Avatar
shaun1979
My cruize control dosent work and I wonder if anyone has a diagram or other suggestions.1986 aerostar
Old May 15, 2004 | 09:15 PM
roree's Avatar
roree
The Haynes book has a pretty decent electrical diagram. Check your brake lights, the cruise uses the filiments to ground. If the bulb is out the cruise may not work. There is also a speed sensor usually located on the rear axle.
Old May 16, 2004 | 11:05 AM
87 XLT's Avatar
87 XLT
Like roree sez it could be a bad speed sensor. Take 2 minutes to pull the codes, if your lucky you will get a code 29 & just need to change the sensor.
Old May 16, 2004 | 06:11 PM
bobcf's Avatar
bobcf
http://www.members.shaw.ca/k2pilot/C...iagnostics.doc
http://www.dalidesign.com/hbook/ccmain.html
Not much for diagrams, but a lot of info.
Bob
