351 w missing
Old May 15, 2004 | 03:27 PM
superhooperduty's Avatar
superhooperduty
351 w missing
just completed a 302 injected to a 351w carbed swap, but the new motor has a miss, tried new cap, rotor, distributor, wires, new plugs, still has miss, pulled wires off one at a time, runs a little worse, so those don't seem to be problem, sometimes when idling it speeds up and and down, any ideas? could it be a vacumn leak? i've also taken off a vac hose or two, depending on which size the motor speeds up.
Old May 15, 2004 | 10:03 PM
Matts72's Avatar
Matts72
bad lifter....
did you rebuild the 351W or just install it?
Old May 15, 2004 | 11:18 PM
superhooperduty
351 missing
yes i built it. new rings, pistons, lifters, rods, cam and rockers, intake, rebuilt carb and rebuilt distributor.
Old May 16, 2004 | 03:07 PM
Matts72's Avatar
Matts72
the only things that I can think of, are a slightly bent pushrod, or bad/broken valve spring.
Pull the valve covers and check to see if anything isn't moving under there.
Old May 16, 2004 | 08:12 PM
superhooperduty
thanks will do. both should be ok, new heads and rods
