Cam Position Sensor??? HELP.
Old Jan 18, 2002 | 02:33 PM
ColtM4's Avatar
ColtM4
Old Feb 2, 2002 | 10:48 AM
ashtonf250psd's Avatar
ashtonf250psd
PSD Buffs...I would like to know where the CPS is located on my 95/96 PSD. From reading on the message board I think the problem I am having with random cutting out/hesitation through all rpm ranges and temperatures. How would I troubleshoot this item? The dealership could not identify my problem. Basically loose power like a fuel pump problem but only from 1-3 seconds, and the dealership said the fuel system was fine.
If anyone could help I would greatly appreciate it. If more information is needed on my problem, please let me know.
Thanks
LovmyPSD
Old Feb 2, 2002 | 11:30 AM
bhmadsen's Avatar
bhmadsen
Front cover of the engine, just above the timing marks on the vibration dampener (if I'm wrong sorry, I'm just looking at the diagram in the CD manual). Right side of the engine as viewed from the drivers seat.
From what I've read over at -diesel.com you can save some money by getting the new one from an International Dealer.
Old Feb 2, 2002 | 11:37 AM
BigDeezil58's Avatar
BigDeezil58
You will need a 10mm wrench and a screwdriver. Takes about five minutes. Then have a beer. Buy two sensors and keep one in the glove box. These are notorious for stopping the mighty PSD in it's tracks.
Old Feb 2, 2002 | 11:49 AM
BigDeezil58
The Diesel Dude had a very comprehensive reply on this subject some weeks past. I forget who needed help, but he had a similar year PSD and Joe helped him troubleshoot this as well. You might search that, or maybe joe will chime in. He is the man!
Old Feb 2, 2002 | 12:26 PM
cyberbyrd's Avatar
cyberbyrd
Had the same type problem with my 95 F250 power stroke. Loosing power and then after a while total shutdown on hills and under heavy load. Truck would always fire right up after shutdown. My first thaught was fuel problem also but thrned out to be CPS. Bigdeezil58 has it right, get two of them and have a beer after the pains taking job fo replaceing the CPS.
Good Luck, Cyberbyrd.
The Diesel Dude's Avatar
The Diesel Dude
The guy you need to talk to is tcpds on page 2 of this forum. He is the one who figured out how to diagnose a defective cam sensor. I work for the company that manufactures the Power Stroke and WE can't even diagnose it! We are just a bunch of parts changers -- trial and error! TCPDS is "the man!"
Old Feb 2, 2002 | 01:40 PM
ashtonf250psd
All,
Thanks for the help. What is the torque for any bolts etc.? I will look for the other posting...I had read one from about three/four weeks back is this the same one? Any recommendation of International dealer online? Or url?
Thanks again,
LovmyPSD
Old Feb 2, 2002 | 05:08 PM
bhmadsen's Avatar
bhmadsen
24 NM or 18 lb/ft
Old Feb 2, 2002 | 05:29 PM
bhmadsen's Avatar
bhmadsen
http://www.internationaldelivers.com/parts_services/content_parts.asp
Old Feb 2, 2002 | 06:02 PM
bhmadsen's Avatar
bhmadsen
$88 at the dealer closest to me. This is off the service manual CD. I've tried to cut and paste the picture but apparently it can't be done.
Camshaft Position (CMP) Sensor
Removal
µ 1. CAUTION:
Make sure the ignition switch is in the OFF position prior to working on the electronic engine controls.
Turn the ignition switch to the OFF position.
2. Disconnect the wiring at the camshaft position sensor (CMP sensor) (6B288).
3. Remove the retaining bolt and the sensor.
Installation
1. Note:
On vehicles equipped with dual batteries, for additional information, refer to «Section 414-01» for battery reconnect procedure.
Follow the removal procedure in reverse order.
Old Feb 3, 2002 | 03:22 PM
BigDeezil58
Just thought I'd add to bhmadsen's excellent reply;
Unless you are really tall, and/or have go-go gadget arms, you will need to lay under the truck. Lay under the passenger side and look at the vibration dampener, then think of it as a clock. The sensor is at 10'clock on the front of the engine. Be sure to have a beer.......or two,etc.
Old Feb 3, 2002 | 06:14 PM
bhmadsen's Avatar
bhmadsen
I figured out how to show you the picture if you care to see it.
Click this link for the service manual page pertaining to the CPS
http://community.webshots.com/scripts/editPhotos.fcgi?action=showMyPhoto&albumID=3050340 1&photoID=30528954&security=lEfwTdLiFz
