Sponsored by: Auxito
Leak at steering box
Old May 14, 2004 | 08:12 PM
Jtown150's Avatar
Jtown150
Hi all , I have a 2000 F150 that is leaking red fluid from around the shaft comming out of the steering box, it's red in color. Looks like tranny fluid. What is it, how big is the problem? Whats the fix?
Help!!!!!
Old May 14, 2004 | 09:29 PM
triton_2002's Avatar
triton_2002
Power steering fluid and tranny fluid look the same (actually I think they are the same). Did you check for a loose hose or clamp? Could it have been overfilled? Have you noticed any difference in the power steering feel? If it is the actuall pump that is leaking, then it will have to be replaced eventually. Maybe you'll get luck and it will just be something loose.
Old May 15, 2004 | 12:02 AM
Racerguy's Avatar
Racerguy
It sounds like your sector shaft seal is leaking.
Your dealer probably stocks the lower seal kit for it.
It can be a bit of a pain to replace the seals though.
