spray over
Old May 14, 2004 | 03:47 PM
1979_F100_302's Avatar
1979_F100_302
spray over
I just got a 85 f150 and the paint is pretty good, starting to fade a little as the clear coat has worn off. The paint is the origional Red and White 2 tone and what I am wanting to apply a new colour coat (dark red pearl) directly to the existing one and reclear coat the whole thing. Is there any problems with doing this? Will it last a few years?
Old May 14, 2004 | 04:36 PM
Aekisu's Avatar
Aekisu
<cr>
If you do the proper prep work and have a good base (no flaking, surface rust, & etc.) to work with, you shouldn't have any problems.
1) Scrub (and I mean scrub because you are going to a paint booth not a car show) with water that contains a good squirt of dishwashing soap (I like Dawn because it does a great job on grease). Rinse with plain water and let dry.
2) Degrease with a grease/silicone remover sold by auto paint stores. Best way to do it, is to spray it on and wipe off with paper towels. Don't rub it around, just spray and wipe.
3) Scuff with 400 (600 for metallics). Red Scrotch-Brite pads are great for those difficult areas.
4) Spray on a coat of epoxy sealer/primer.
5) Apply your favorite finish.
Old May 14, 2004 | 05:27 PM
1979_F100_302
Thats what I was hopeing, Thanks.
