Sponsored by: Auxito
clutch trouble
Old May 14, 2004 | 03:34 PM
okiejoe's Avatar
okiejoe
Smile clutch trouble
I just bought a '01 f150. drove fine till a couple of days ago when the clutch pedal went soft. Now it won't go into gear unless i pump the clutch. is there fluid i should check? I am not much of a mechanic. thanks in advance.
Old May 14, 2004 | 04:23 PM
david.brady's Avatar
david.brady
Uh oh . . . Sounds ike you either have a leak in your line somewhere or you are almost out of fluid and there is an air pocket in the line. Either way, check your master cylinder. You may want to follow the line to the clutch fork and the slave. Down by the slave there is a valve, used to bleed the line, make sure it is tight and not leaking fluid. Fraid that's all I can help, hope what I said is right and I'm not confusing it with something else, been a long day.
Old May 14, 2004 | 04:25 PM
okiejoe's Avatar
okiejoe
thanks but Im not sure where the master cylinder is? does it say dot3 brake fluid?
Old May 14, 2004 | 06:31 PM
triton_2002's Avatar
triton_2002
Yep, its that little plastic cup high up on the back of the engine bay (drivers side)
