Help on this One Guys.
Old May 13, 2004 | 07:50 PM
Fully_Loaded's Avatar
Fully_Loaded
OK after viewing different threads and starting my own I am still confused. This is what I got. I have a 91 f150 with a 302. I bought another motor for it and am putting it in right now. The new motor is a new (freshly rebuilt) 88 mustang 5.0 roller cam. I have speed density set up. My question is do I run the 351W firing order or stay with my truck firing order. I am using all my truck components on this motor. I have changed the cam in it and I got the steel distributor gear. Please help I need to know what firing order I have to use.
Old May 13, 2004 | 08:35 PM
Chris_ce's Avatar
Chris_ce
You need to set the firing order for the cam you put in. If for the 351 then thats the order .
Old May 13, 2004 | 09:13 PM
pfogle's Avatar
pfogle
did you put the standard truck cam in or one for the 302HO/351?
Old May 15, 2004 | 09:53 PM
Fully_Loaded
I put a summitt truck power cam in it. It said the application was a roller 302 so I assume I run the 302 firing order right?
Old May 15, 2004 | 11:43 PM
pfogle's Avatar
pfogle
SO it was not listed as 351w/302HO, it was just listed as 302, then yes the 302 firing order is correct.
Old May 16, 2004 | 08:37 PM
ga302p's Avatar
ga302p
Set your fireing order to your cam card. It will tell you the correct order. The h.o. order is getting mort popular.
